traction control
owlkid
Can you just get a switch put in where you an just push it to turn it on an off??
Doesn't simply work like that unless you build a specific bypass module to do so. That involves messing with your wiring to the ABS actuator.
Thanks Djkor I'll probably just leave it then I no nothing about cars so I don't wanna screw round with it seems to complicated for me, I tried the break on/hand break so on thing but couldn't do it, so thanks for the help anyways
  • 2 years later...
