LC 200 Diesel Tapping Noise at low revs
Tow bar
Snapping wheel and axle studs
Thanks, looks like manufacturer can only replace. I've reached out to my Toyota dealer (where I purchased) directly. -
Try a search for compliance plate replacement. Herb
