aurion head unit upgrade need help
kcir
Hi, i tried the latest toyota touch screen head unit PZQ6000521 on my 2008 aurion. I got an antenna patch wire, the audio and bluetooth work no problem. But the steering wheel controls including DISP button are not working. did I use the wrong cable? or do i need another patch cable? could anyone who has done this before advise the part number? Thanks
which patch harness are you using ? any of these
You need to get the harness on right that is the 1 the steering wheel control wires are in.
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
