Tarago with Oil Sludge problem
Roelfk
I have a 2007 Tarago V6 GLX.
I took it for a 120 000 km service and was told by Toyota that I need to replace the engine because of an Oil Sludge issue. The engine is getting noisy too.
I would look like to know if anyone else had a similar issue?
I'll have to replace the engine with a used engine as it is too costly. Does anybody have experience with used engines?
I have heard the sludge issue with v6 engines in the us and the odd engine over here, but I think its more to do with lack of maintainance and missed services,did you buy the car new or do you get the car regulary serviced because in general I think the toyota v6 and other engines are pretty durable and reliable.
The cost of a new v6 engine would be eye watering exspensive , yeah a low km used engine would definetly your best bet, 3.5 v6,2GRFE is a common engine, so you wont have any problems locating one, theres wreckers in metropolitan areas that just specialise in wrecking toyotas, they would be the ones I would try,hopefully mate everything goes well for you and lets us know how you get on.
HI
I managed to get a used engine but also lodged an Out of warranty Assistance with Toyota.
I am waiting for Toyota's response. It seems as if Oil Sludge is a contentious issue and in the US Toyota had to repair many engines.
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
