Sportivo flywheel bolts torque specs
JDee
Hi guys i've tried searching the forums but couldn't find what i was after..
I'm installing a new exedy hd clutch tomorrow together with a lightweight flywheel so i was after the torque specs required for the flywheel bolts?
any help is grealty appreciated.
thanks!
Thanks for the input guys, appreciate it! As they were ARP flywheel bolts i managed to find em on the monkey wrench site. If anyone needs it in the future they are:
ARP Flywheel bolts torque spec: 58 ft-lb with ARP moly lube or 85 ft-lb with 30wt motor oil (monkey wrench racing)
OEM Flywheel bolts torque spec: 36 ft lbs (newcelica forums)
Pressure plate bolts torque spec: 15 ft lbs (newcelica forums)
Transmission to engine block bolts torque spec:
The two upper ones that bolt from the tranny side into the engine block ar 47 ft-lbs.
The two middle ones on the differential side that bolt from the block into the tranny ar 35 ft-lbs.
The two lower ones that bolt the block girdle to the tranny bellhousing are 17 ft-lbs.
(Newcelica forums)
If anyone can clarify this, please do so!
      Towbars
    2. 5
      ASV50 Camry Head Unit Options
    5. 2
    8. 14
    9. 2
      Hi from Wagga
