Camry stereo
Yes it can. The Genuine unit from Toyota (the ones on the Camry Grande) cost quite a bit....
You may also consider getting an after market one for fraction of the cost.
Don't bother with the one that was in the Camry Grande, it's rubbish and very outdated, and was never available as an option on other variants anyway.
Best way to go OP, grab one of the new gen 2011 AVN units (same as in current spec Hilux SR5, Corolla Levin ZR etc.), part number PZQ6000531PA and facia to suit the 200mm double DIN Toyota radio size part number PZQ6033030. You may need a harness as well (about $30), check with your local Toyota parts dept.
Edited by pinzvidz
