Anti theft alarm system
Ratheesh Kumar
Does any one know how to engage the anti theft alarm on Toyota kluger grande as i can see the alarm switch on vehicle key.If some one touches my car does the alarm go off,i can not see that happening with my vehicle.Could some one provide an advice.I know engine immobilizer system there with the car but is there any thing to protect from unauthorized entry to the car.
If someone touches your car, no the alarm will not go off, if they open the door then the alarm should of off, try unlock the door with the key and see if the alarm goes off from not using the remote.
The tech from Toyota dealser said me today that the alarm sytem with all toyota vehicles don't have the capability to make panic alarm ifsome one touches the vihicle or door handle,but does have a switch on key to make others panic if they appears to approach your vehicle for different purposes.Also told me i can buy an aftermarket system to add this as an additional feature to the current security system for my Grande.Have any one heard this before,the alarm system that toyota gave you is not for useBut engine immobilizer will work when they try to start our vehicle.(Means any one can open the door with out any noise).
Edited by Ratheesh Kumar
      ASV50 Camry Head Unit Options
    5. 14
      Hi from Wagga
    8. 2
    9. 2
    10. 2
