rear lamp failure warning module
cam6
G'day all,
I've got a 2000 model Camry (Vienta Grande), and the rear lamp failure module is playing up.
Rather than replace it, I'd prefer to simply get rid of it.
I regularly check all the lights when I hook up the boat, so why pay Toyota for an unnecessary complication?
Has anyone done this? Did it all work OK?
If so, can you give me a rundown on it?
Thanks John
  • 4 weeks later...
For general info -
Toyota wanted $420 for the module!!
Prior to the above post I was going to do it myself. Who needs it ?
What made me a bit hesitant was that I saw the wiring diagram,and it showed a wire going to the computer. This had me puzzled so I chickened out. I didn't want to interfere with any sensor inputs.
I paid an auto electrician to do it. Cost $77.
In retrospect, the wire was probably just a test wire, so had no operational use, and could have been removed.
John
      Corolla Seca For Sale
      Toyota Corolla Sportivo
    6. 2
      Toyota Landcruiser problems
    9. 7
      selling car
