Air Conditioning Help (1990 Aussie model)
camry1990
Hi All,
As a novice in cars, I was wondering if anybody can kindly help with a problem with my air coniditioning in my 1990 Camry CSX.
The air condition works on the III and IV Levels but I and II doesn't work. Both the Economy and A/C Normal mode works properly. I suspect it's a blown air con fuse??
Can anyone shed any light onto this problem? Thanks.
PS: If it's the air con fuse, where do I find this?
Thanks in advanced.
Hi
DO the lights not come on when on the 1 and II settings? :huh:
Is it all the time?
A slap on the side where the Heat/Vent controls are of my 1990 used to fix many ailments such as the lights not working on the dash. :lol:
Not sure, will have to check tomorrow, too late to go outside and check now. The fan doesn't turn on though at these levels.
As for the 2nd question, ALL the time. It used to be just Low that was dead and now I is dead as well. Can only use II and High now but this is annoying cause on some days here in the city of "four seasons in one day", all you really need is a Low or I level.
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
