Lift Bolts
51EKA
It's been confirmed that the australian celicas do suffer from broken lift bolts like the american celicas. Recently two of ozcelica members had their lift bolt checked by toyota and both had broken bolts. But lift still worked on both cars.
Wondering if any of you guys have check your bolts?
the engines in the celica and sportivo are actually diff, if you look at the two cars side by side you will notice that they are physicaly diff, mostly around the intake manifold, so its not a surprise that an issue that effects one car does not effect another, also the celicas are made in JP? the sportivos are made in SA, mabey they got somthing right over there...
As quoted by toyota Australia and we believe everything they say right :angry::angry::angry::angry::angry: there are no build qualities out of south africa <_< <_< <_< <_<
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
