2005 toyota hilux sr dual cab
waiwong38
hi I bought a 2005 toyota hilux sr dual cab last week, take to mechanic service and found oil leak here there need fix,there Rear axle to fix can cost lot money each side can round 1300 both 2600 looking second hand parts , should I get new or second hand axle?
Why do you want an axle? what's wrong with the ones you have? Sounds a lot like he's trying to frighten you into paying too much for a simple solution. Get another quote, without revealing the first. Tell them nothing, let them diagnose and give a detailed report. It's an easy test of their integrity-which you MUST be sure of if you're going to be a repeat customer. Where is/are the leak(s)? Is it gear oil or brake fluid? Is it a serious leak, or just a weep from a joint? How much oil is in your diff, and when does it need changing? If don't know assume NOW for safety. Ditto all other oils and liquids. When was the cam belt last changed or due? Has it been done? water pump replacement, thermostat, themostat housing? See above. Prevention is ALWAYS cheaper than cure-unless ur tinkering, which is THE most expensive form of "maintenance" known.
More info needed - 05 was a changeover year so which is yours? Also more information needed about this "leak", the rear axle could potentially leak in a few places but depending upon where affects how you'd go about fixing it.
      1993 Corolla Seca CSI limited
    3. 15
    4. 2
      Navigation absent ? From apps 2016 atx model aurion
      Landcruiser Prado (150 series) AVS suspension
    6. 2
      93 Landcruiser Trip Meter
    9. 2
