I am stumped - once you set a destination and want to cancel it, how can you cancel apart from selecting a new destination??
Please - drives me crazy!
Nearly as bad as trying to add contacts on the shortcuts or the fact you cannot dial a number whilst in motion.
Hi , i have the after market Toyota Sat Nav , so it could be different but just double check this as it may be the same.On mine while driving and you want to cancel a route , on the very top right hand corner is a small grid box , when you touch this it opens up 6 new choices.One of these choices is to cancel your current route , you click that box and it asks you are you sure and you click yes.
Maybe yours is the same?
Dan :)
    2. 5
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
