I'm trying to find an inexpensive DIY alignment kit i can use on both my daily driver and race car. I came across this website and was hoping someone could tell me if i should go for it. i added the link at the bottom. ive read quite a few reviews just looking for opinions?
www.quicktrickalignment.com
Posted (edited)
the one i used was a manual one its sort of like the video
so it looks ok ....guy did not demonstrate
both sides in action
how the system worked for a 4 wheel alignment
does the computer and softwear data suit your needs
the system used one clip on level .. how acurate will it be after much use
this system is better demonstrated and you can buy... 4 wheel units
you need all the bits in the video including the turn plates
extra
it had a set pole with markers to get the center of the wheels
longer than the width of the car and triangle supports for the concrete with a level
now a picture of that would be helpfull .....no got
if you have the workshops connections and equipment one could be made from scratch
Edited by dirty hands
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
