tarago radio/cassette
tarago_1993
Does anyone know how to remove the radio/cassette from a 1993 tarago, need to upgrade to a CD/Radio/Cassette as it has no volume control.
Thanks in advance.
TO REMOVE REMOVE 2 SCREWS UNDER FUSE LID,
REMOVE ASHTRAY AND 4 SCREWS BEHIND ASHTRAY DRINKS HOLDER IF FITTED
REMOVE CIG LIGHTER
JIGGLE OUT DRINKS HOLDER AND ASHTRAY ASSEMBLY YOU MY NEED TO REMOVE BOTTOM CENTRE GLOVE BOX IF FITTED
REMOVE 2 SCREWS UNDER RADIO THESE HOLD RADIO MOUNT TO A PLATE IN DASH
YOU SHOULD NOW BE ABLE TO REMOVE RADIO AND VENT SHROUD AS A UNIT CAREFULL OF VENTS
Thanks in advance.
REMOVE CIG LIGHTER
HEy if you have a wiring diagram for this model id be grateful it you would post it!!!!!
    4. 14
      Hi from Wagga
    7. 2
    8. 2
    9. 2
      Engine oil dipstick reading
