I have a harshness feel and sound from the front right wheel. I swapped wheels L to R but it is still there so it is not the tires. I suspect it is a bearing and it is worse when that side is loaded more. My questions are, do you think it is a bearing? which bearing do you think it is? Is it possible to do the repair myself with good mechanical knowledge and with standard tools?
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
