Fog Light Install 09
Aussie Camry
Hi guys,
I ordered a set of fog lights for my Kluger 09 but I wanted to know if the wiring is there for the factory fitted ones to the stalk inside the kluger ?
Would rather have it set up this way then an extra switch on the dash and accidentally leaving them on in the car park.
It's illegal to have them on without atleast having the parkers on.
One of the reasons why I would like to have them set up like the factory install like in my Camry Sportivo.
The full wiring is there, but you do need to order the factory stalk with fog light switch for it to work (try and source one from a wreck maybe??).
It is just a matter of removing the plastic blanks where the fogs are meant to be, and reaching up you will find the wiring taped there. Plug the fog lights in, fit the new stalk and fitted just like factory.
That all sounds great will track down another stalk with fog option.
Do you know if the wiring is also there for the Auto lights option as well ?
I never tried this mod. I know you would need the dash light sensor, but I guess if wiring is there could be just a matter of connecting the dash sensor and stalk with auto switch?? Can't confirm this one though sorry.
I picked up a stalk from a Toyota wrecker in Melbourne today plus a fog light relay.
The stalk was out of a 2013 model kluger but this one has two fog light symbols one clearly for turning on the fogs but the other at the top just flicks what is that used for ?
I was told I will not require the auto light sensor.
