Hi guys...I just replaced the clutch and slave cylinder in my sons 1999 RZH Hiace...but when pushing on the clutch pedal, the pressure seems weak, and then intermittently loses pressure.
If im under the car pushing pressure on the clutch fork ( trying to push the pin back inside the slave cylinder,and he pushes the clutch pedal, he tells me he can hear the slight sound of air escaping..so Im guessing the Master Cylinder has expired ( the car has 300klm on the clock ).
So, what trick is there to taking the Master cylinder out from under the dash? Just getting the split pin off the piston where it attaches to the pedal looks hard enough..
Im guessing i can remove the hose at the reservior..but everything else??..holy hell..
Please Help!!
  • 3 years later...
Have the same problem.  Whats the easiest way to get master cylinder out?
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
