coil igniter
flipperau
hi all I have a 92 RN85 twin cab 22R which I suspect the coil ignighter has failed as it has no spark. can anyone shed some light on the different types of coil ignighters??? there are so many different ones!!!
do they all run the same??? some with round plugs some with square. what is the difference between them??? anyone know??? the one to suit mine number ends in 270 which I cannot find any anywhere. does the 300 work the same???
hi guys I have attached the photo
cant seem to find one anywhere !!!!!!!!!!!!!!!!!! is there some difference between 92-97??? there is so many different numbers in this range. anyone know the differece
post-38630-0-37519500-1436823125_thumb.j
      ASV50 Camry Head Unit Options
    5. 14
      Hi from Wagga
    8. 2
    9. 2
    10. 2
