Posted (edited)
Hi,has anybody had trouble with revs being high at 100kl/h.My 2015 GXL 200 series taco reads 1900revs when doing 100kl/h and if i run with the cruise control and raise an lower my speed it drops to 1700 revs still doing a 100kl/h.Its as if it stays in 5th gear then when I change the speed with cruise it drops into 6th gear.Or is it that the taco is just reacting to the road conditions,never had a 6 speed Auto Any ideas
Edited by Pete65
Hi Pete,
What you need to do is, when you are driving move the gear shift into sports/manual and upshift into 6th gear. then put the gear lever back to normal driving position, this changes the mapping on the gearbox to change into top gear at 100-105km. every time you turn the car off it will reset and you need to do this procedure again
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
