Cluster Illumination
TRDsx6
Hello Aurion brethren
My sx6 cluster is not dimming when i activate the parker lights as it should. Is there settings for this or is there something not right?? I know this is wrong because my dads 07 touring's cluster dims once u activate the light.
Please feedback will be very great!
Turn the knob located in the cluster to the left. It is likely turned all the way to the right. Once it is past the bump, it will not dim.
Yes! it worked! thank you.
      Code P004B
      Upgrade from 2012 to 2023
    6. 3
      Towbars
    7. 5
      ASV50 Camry Head Unit Options
    9. 2
