1st & reverse gears not engaging
Old Girl.
we own a very faithful 1989, 4X4, toyota hilux, 3L, 2.8 D, LN106.  the engine purrs like a kitten, only problem is the gear box.  only will go into 1st & reverse
gears when the engine is stopped. question! as we live in the middle of Australia , Tennant Ck, NT, a long way from major cities, what is the best way to correct this problem. at this time it is unregistered & will require a road worthy pass to register.  would be grateful to any suggestions or ideas.
Suggest changing the transmission fluid. Consider replacing the transmission filter [if it has one]. Not sure if your gearbox has shift solenoids, but if so, remove then check/clean the fine mesh screens.
      Upgrade from 2012 to 2023
    5. 3
      Towbars
    6. 5
    7. 2
      ASV50 Camry Head Unit Options
    9. 2
