Aftermarket headunit
Azr87
Pull switches out then use a plastic trim removal tool to pry off front bezel. The headunit will be screwed in with 10mm bolts.
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
