Hello, front diff vibration
I have a 2010 GXL turbo diesel IFS landcruiser.
I had an issue driving to Exmouth and it dumped the oil out of the front diff.
I was able to fill with engine oil but it was noisy and I had quite a way to go so I dropped the front shaft and put it into centre diff lock and kept going.
I ended up rebuilding the diff and decided to put in an eaton locker at the same time. since back together I have a bad vibration that comes in under load about 45 kph and goes at about 70
If I drop the front shaft it is not there, I have pulled the let side (where it seems to be) apart and checked the inner CV, intermediate shaft, was new brg in Kit. Checked the play in the pinion etc. Couldn't find any issue is drive train, found the let side diff bracket rubber bush cracked so changed it and the vibration feels worse.
Everything tells me there is something wrong in the input to the diff but I cant find it.
Any help welcome
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
