I am trying to upgrade the headlight bulbs on my 2016 Camry Altise. Although I can get at the drivers side bulb, it is impossible to remove the passenger side as the fuse and relay box is so close, giving only about 1" of room to get my hand in. The problem is made worse as there is a plastic cowl round the back of the headlight. I can get the rubber cover off but that's it.
Also, what is the square plug with 4 wires between the high and low beam lights.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
