G'day guys, 99 camry wagon issue.
The central locking wasn't working so I have purchased new actuators, I did the drivers front no problem. I did the rear left and stupidly (but somewhat understandably) closed the door without a thought, now I can't open it from the inside, or the outside. The rods that are visible are connected, I can't really get in there much as there's a shroud across the back of the mechanism.
Thankfully the inside trim is still off, looks like I may have to remove the glass to remove the window guide and get some more access, or take the whole door off from the front and possibly get it off the catch that way.
Anything else I should try before I dig myself into a deeper hole?
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
