T20 Gearbox
G'Day all hoping someone can help, I have a clubman style home made vehicle.... which at the moment has a buggered starter motor, my problem is the starter motor is so old all identification marks are worn off... I fitted a t20 gearbox rear wheel drive gearbox to a 1.8 litre fuel injected corolla motor out of a front wheel drive... my question is: what model corolla used the t20 gearbox if I can track down what motor was coupled to that gearbox I may be able to locate the right starter. Thanking you all.
No such thing as a "T20" gearbox in Toyota-world (there are T-series manual gearboxes, but a 20 would indicate a 2-speed).
Would help if you give the actual code for the engine too, as "1.8L fuel-injected" could refer to several different engines (which has a flow-on effect for gearboxes too)
Sent from my SM-G970F using Tapatalk
    6. 21
    7. 21
    8. 21
