Failed power seat switch - manual adjustment
L4WL3SS
Something thats bugged me about my wrecker sourced powered zr6 seats is the driver seat height adjustment has never worked..
Have narrowed it down to a faulty switch assembly which is near impossible to source without buying the whole seat. Using my own dpdt switch & running power straight to the motors only made it go up to max height & now i have a bigger problem haha.
Surely theres a way to manually adjust it but after a quick inspection it looks pretty daunting. Any ideas?
Edited by L4WL3SS
I couldn't see any way of manually adjusting height, so i tried the dpdt switches again, but this time instead of piggybacking into the circuit, i cut the motor plugs away from the factory loom....... And bingo, it all works, and i can adjust downwards without wires melting.
Obviously a replacement seat switch is needed, but this will do in the meantime
 Thanks to the following page i was able to understand how to wire the switches up to the reverse polarity motors.
https://www.vegoilguy.co.uk/reverse_polarity_switching.php
Edited by L4WL3SS
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
