DIY Painting
Hey guys
Wanna paint my rear mudflaps.
They are only small - so I thought I could buy a spray can and do them myself.
Anyone know if it will look shiet? or woul dbe ok since its a small piece.
Also what paint would i use ?
cheers
yep, it's easy to do. Just remember the finish you get will come down to your prep work.
You can buy custom-mix spray packs from autobarn for $26ea, one will do a set of mudflaps easily. I've done a whole bumper with two of them a couple of years ago.
Get the paint guys to put some flex-add into the paint so it had a bit of flex in it and wont crack, and use plastic bumper primer to prime the mudflaps after scuffing them with the scotch-brite pads or 800 grit wet/dry.
I give them a couple of coats of bumper prime then rub them back lightly with the 800 wet/dry so the colour coat can key properly to the smooth primer. After a couple of coats of the colour, I then give 5 or 6 coats of clear... Should turn out very nice. Just dont put the colour on too thick like pippy ;)
Sweet thanks man
Autobarn sell all that stuff right? i might as well give it a go
yep, autobarn sell it all. Also get some prepsol to clean the surface of everything.
if its gonna cost close to $100 might as well get them done professionally.
nah coz if that goes well then ill do my front undergarnish as well
Painting mudflaps... I think I might do that as well! :D
Let us know how you go Romp. :)
alright - gimme a few weeks tho - heaps bsuy at the moment
Ill try to take pics but my digi cam is old and crappy:)
      Aurion tyres
      Aurion tyres
      Aurion tyres
    5. 2
      Just joined
    6. 2
      2016 Hilux SR5 Coolant Issues
    7. 2
    8. 2
    9. 1
      ZRE182 Nudge bar
