King of the Hill
blue_rolla
  • Replies 14.3k
  • Created
  • Last Reply
Top Posters In This Topic
  • MarkMish
    2021
  • Sportivo05
    1579
  • eggbert_99
    1442
  • MT
    1262
Posted Images
Mish queen AHHHH!
Congrats.
Heres your instructions my Queen :D
Before putting the side skirts on wash the underside and bottom side of your car where the tape will be sticking with dishwashing detergent. This will get rid of all of the wax so the double sided tape will be making proper contact.
1. On the very top of your skirt there should be double sided tape. Use some scissors to cut the red backing plastic in the middle of your skirt and fold the backing to the top so the backing is sticking out. Have about a 5cm gap showing the sticky part.
2. Also fold all the other red backing so you will be able to pull out the backing then the skirts are on.
3. Put double sided tape all along the inside bottom of the skirt so when the skirts are on it will grab the bottom of your car. Do the same thing by cutting the red backing in the middle and fold them out so you can pull on the tape when the skirts are installed.
4. Screw in your skirt to your car using the included screws and clips so both ends are connected to your car. You will notice that the skirt is sagging as the middle is not supported.
5. Using some Telephone books prop-up the middle of your skirt so it aligns in a straight line all along the bottom of the doors.
6. With the middle part where the sticky is exposed push the skirt up all the way it can go and then press the skirt/tape onto the main body. Keep pressing for at least 30 seconds so the tape grabs onto the body properly.
7. If you can get a second person pull the red protective from the top of the skirt bit by bit and pressing each section for at least 30 seconds so it grabs properly.
8. Keep doing the above steps until all tape is making proper contact. Remember to press the tape for at least 30 seconds for each section. A little time now will save a lot of time later.
9. When all the tapes are done tighten your screws but be careful of the front ones as these ones you can strip the inside.
ok thanks phill................if this dont work.............u will be getting a phone call...............hehehe
thanks my lawful servant!!.......... :P
