Slam ball (if you like basket ball, NFL and ice hockey)
1987 Toyota Corolla - 60 000km on the clock
Hi All I have a 1987 Corolla with 60 thousand kms on the clock. Immaculate condition on the inside, starts first go and all original. Looking to sell. What would this be worth? Thanks -
Toyota Landcruiser problems
13
300 series turbo issues
55
Stout Owners
13
8
55
Stout Owners
Did you get a resolution to this missing yellow line issue? I have the same problem with the same year and model CH-R.
