Cruise control not working 2007 Tarago
Tarago07
Hi all, I just got myself a 2007 Toyota Tarago. Drives well and looks to be a good car, only issue is that the cruise control doesn't seem to work? When I press the cruise control button on the lever nothing happens, there's no dash light either. I thought it might have been a blown fuse, but now I'm thinking there may be an issue with the dashboard cluster, as there doesn't seem to be any lights under the speedo but looks like there should be? Is this where the cruise control light normally shows, and does anyone have any troubleshooting suggestions? Here's an image of the cluster - https://postimg.cc/pp4v3cSW/40e42886
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
      Upgrade from 2012 to 2023
    9. 3
      Towbars
    10. 5
