Correct engine oil for 2003 camry
Toyota 3L shakes on idle
Hi, did you ever sort this problem? I am having the exact same problem, have also replaced all the mounts, it's driving me mad. -
2019 problem's,I have a gx auto petrol looking at buying but need to know what I'm buying $34000.is a lot to pay out ,what yah think. -
Android auto
I have the Cruiser Hybrid 2024 and can confirm that AA wireless is not working, still needs the cable. I'm a bit disappointed because my phone won't fit anymore in the wireless charger tray. -
Hi!
Hi to all! Derek here, recently got our RAV4 Cruiser Hybrid 2024 from almost 2 years of wait. Before that we have and still keeping our trusty 2008 Corolla. I join the club because I'm a bit overwhelm by the features and the new technology that came with the RAV4, my wife is afraid to drive it because of this, more fun for me. 😄 Cheers, Derek -
Timing issue, 1994 st204 celica
I’ve got a 1994 st204 celica with a 5sfe motor, it runs perfectly for 15-20 until it warms up then it starts misfiring and stops. Then when the engine cools down it will start and run perfectly until it warms up again. I have replaced the igniter, internal distributor coil, distributor cap, rotor button, spark plugs, spark plug leads. Any suggestions would be greatly appreciated! -
8
Car Service and Car Tune Up?
I think this is normal, auto choke engaged when starting and comes off after the engine warms up. Giving gas resets the choke. Herb -
Hilux Workmate 2x4 bulbar installation...
I've got a few questions regarding the installation of a bull bar on my 2006 Toyota workmate Hilux 2x4. First off, the bulbar I am looking at will weigh around 30kg and I was wondering if would need to try and get some heavier duty shock absorbers and springs to compensate for the extra weight. Keep in mind that this little 2x4 gets a run for its money and is put mainly through the scrub, basic 4wd tracks, and corrugation. Secondly, The bull bar I have purchased is for a KUN 2005-2012 Hilux body shape, which from brief research will fit. A bit of confirmation would be lovely in terms of will it actually fit properly. Any help and or insight would be lovely. -
Check the spark plugs. Also consider cleaning the throttle body and idle air control [IAC] valve. Search YouTube for the relevant videos for your vehicle on how to do this. -
8
Hi, I have a Toyota Corolla 2 (Model - E-EL41 -Manufacture year 1994) . When the car is start the engine idle is not maintaining. After 10 , 15 minuets Its became normal when apply more gas. Can I know the is reason for that?
