Dyno Tuning Toyota Corolla 1992 FX GT
Yousif Iskander
16 hours ago, Yousif Iskander said:
Would anyone be able to guide me to a workshop that does Dyno Tuning for a Toyota Corolla 1992 FX GT. I am in Sydney
Unless you have an aftermarket ECU/piggyback, there is nothing that a dyno can do for you other than tell you how much power you're making and if your AFRs are ok.  Factory Toyota ECUs are not tuneable.
If you are running aftermarket engine management though, then you need to look for shops which have experience with that brand/model of computer, not so much the car (a 16V 4AGE is a pretty simple engine that any decent tuning shop can handle)
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
