2003 aircon relay location.??
danzo45
hi all, ive searched and searched but the online pics and instructions lead me down a false path...
2003 tarago aircon relay?? i can not find it at all. ive looked at all 4 fuse /relay locations and they dont have the same as on the pictutres///
can anyone that has changed one help?
we can jump the system to the pressure switch and get it to turn on. but even though the interior switch is on and the light comes on the switch wont turn on the actyual system
if you can get the air compressor to work by jumping the pressure switch. Its either you have a faulty pressure switch or you're low on gas.
The pressure switch must be faulty. That's where it's leaking from.
So new pressure switch. Should work?
I was thinking that might be the case... backyard gas fitters 🤣🤣
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
