2008 200 Series Toyota Landcruiser VX  diesel. I have owned the above vehicle for 14 years and done nearly 400,000 km but in the last 9 months the batteries in both remotes have had to be replaced 3 times, the last batteries only lasting a couple of  months. We have not changed where we store the remotes, so am at a loss to explain the current problem. Has anybody else had this problem, and if so what was the fix
I would think that the batteries are beyond their use by date. Change vendor and / or check the dates on the package.
Herb
Different vendors, last batteries supposed to be the best. In addition it is both remotes that are going flat.
There was a post on the now defunct LCOOL forum whereby you could put your remote
in a 'sleep' state and save the battery. It seems the remote is constantly looking for a signal
which in turn drains the battery.
  • 3 months later...
Yes having same issue mine going flat after few days tryed new battery’s in both keypads with same issue out be in the car I’m thinking guessing did you have any luck with it
      Tow bar
    2. 3
    3. 0
    4. 3
    5. 3
    6. 3
    7. 1
      Snapping wheel and axle studs
    9. 2
