RAV4 19" wheels on Aurion
Alot of plant debri flying around today. Whipped up a spray booth. Not ideal, but it's what I've got to work with. Let the painting begin 👍 -
New Headlights Flickering Out
I installed new headlight bulbs in my 2007 RAV4 recently. However, every time I turn them on they both flicker out simultaneously after about 5 seconds. What could cause this issue? I don't think it is the bulbs because they can be turned back on again, and there are no blown fuses. A friend mentioned something about a ballast, but I am not knowledgeable enough about car electrics to do anything about that. This is the description of the bulbs: Product: HID Xenon Bulb Material: Quartz tube + iron bracket Voltage: 12V Bulb Type: D4S (can also fit D4C, D4R as well) Base Type: P32d-5 Power: 35W/Bulb Light Source: Xenon HID Light Color: Yellowish White light Color Temperature: 4300K Luminous flux: 4500LM ± 200LM Waterproof: IP65 Beam Type: Hi/Low Beam Part Number: 66440CLC Bulb Size: ( L x W ): 7.5 x 3.2cm Socket Base Dia. : 1.8cm Weight: 200g approx, I would appreciate any help or advice. -
2006 Toyota Corolla Seca Looking for advice
Just got some black stock sportivo wheels 16s Looking for a 2005 toyota corolla sportivo side skirts rear spoiler/boot and front bumper. -
Driver's seat base leg support.
Just picked up a 2015 Ascent Sport and this is my first post. did a return trip Brisbane to Tweed heads and very pleased with it. I have one issue that I would like to correct if possible. I find that the front edge of the driver's seat is too low and provides no support at all under my legs just above the knees. I am looking at trying to elevate the front of the seat base if possible. Any suggestions welcome. -
Head light Relay Location corolla 2005 wagon Japan ver. 4AT
Hi guys, I was so many diagrams but my car is different. The head light Relay spot is empty in my car. Can anyone help me to find the relay actual location? When switch the head light on, I can hear click sound under the steering wheel but I can't see any relay there. -
1992 1hdt both blinkers flashing together
Hi Tony, I don’t think so. When operating the hazard switch the dash lights are quite bright. When I turn either blinker on they are not as bright. I think it is an earth issue, maybe in the blinker switch. I’ll pull it out tomorrow and clean it with contact spray unless someone has a better idea 😁 -
Problem with the hazard warning light switch? -
Rear speakers?
On my dual cab SR rear speaker wires and Plug were already in place, I just got a couple out of a SR5 from the wreckers, perfect, Get yourself or make a Memory saver, ( 9v smoke alarm battery, 2 alligator clips, and the plug and 2 wires from Jaycar ) worth every cent and saves resetting everything if battery is needed to be disconnected Safety 9V Battery Clip - Highest Quality | Jaycar Electronics -
Centre Bearing Replacement
Check if there is a Front Arrow and the centre bearing is actually running in a straight Plane, what are the uni's like, For you to experience Shuddering, its pointing to a Flogged out Uni. Don't know about the smell of burning rubber, if you greased the uni,s might be just grease on the exhaust. Put it in gear 1st, hand brake off and get someone to rock the vehicle back and forth and get under it and visually look and feel each and every uni and also the slip joint near the centre bearing for excessive play -
Wheels arrived today & I had time to sand one of them with a SIA green superfine pad (500-600g) Much better already 👍 Regarding tyres, I've purchased a set of Nexen N'fera Su1 in 235/40r19 for $220 fitted which is pretty good for a mid range tyre
