Hello, i have a 1996 starlet
The problem is when i turn the key the fuse blows, and i have been looking over the wiring and can’t find any shorts or damaged wire. The car would not crank over because of the fise blowing.
I found out that if i disconnect the transponder key ecu the fuse is holding, but as soon as i connect the transponder the fuse blows.
So i wonder if there is something I can try out? should i just buy a new transponder box or is it something else i could try? and is it not kinda wierd that the box is the problem?
I have looked inside the box and cant see any corrosion in the box
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
