I drive a 2010 series 200 sahara V8 automatic.
I recently towed a small caravan on a not that hotter day.
The temperature gauge went to about half then dropped back to normal. The motor then went into limp mode and eventually stopped.
On lifting the bonnet i noticed the top radiator tank had split all the way across. I have only two months ago had the complete cooling system checked with no defects.
I called the RAA in South Aust and they tried to start it but just turned over but did not fire up. It was still pretty hot. I have been told the motor would be ruined by overheating. The car has been sitting at the repairers for 5 days now and as far as i know it has not been attempted to start.
Before putting a new motor in it would it be worth putting a new radiator in it and see if it will fire up?
Open to any suggestions at this stage.
      Tyre Sale Specials
      overheated engine
    4. 62
      Tyre Sale Specials
    8. 10
      Remote start
