Fitting k&N to TRD CAi
Hi GUys
DId a search cant find much.
When replacing the TRD filter which i have found has a flange of 70mm or 2.75 inches how did u connect the K&N extream filter RX-3900.
If the pipe is 2.75" as the trd is and the K&N has a ID of 3" as the sites states then did you need any adaptors to fit it? like a reducers from 3" to 2.75
thanks guys
Edited by SyxXPaC
Hi GUys
thanks guys
just do up the hose clamp more, works fine.
