So finally I got them fitted this morning, looks really great with the lowered height but during the wheel alignment, both wheels in the rear (both sides) showing -30mm camber and he couldn't adjust it at all. The fronts are fine which set at 0mm after a bit of adjustment. Sad thing is they didn't have any camber kit in stock and have to order them in. Does anyone have this problem as well after lowering?
Other than the camber, I also noticed some scrubbing in the front - when cornering, and in the back when driving over uneven road. I'm not sure if it is because my car is too low, I have attached two photos.. *EDIT* I'm running 245/35/19
Any idea/suggestion would be great so I can go back Pedders and ask them to check on the issues...
Thanks
