D'Ice
About D'Ice
  • Birthday 10/29/1987
    Camry SV21
    Sydney WestSide
4,350 profile views
D'Ice's Achievements
Veteran
Veteran (13/14)
  1. seek and you shall find... http://au.toyotaownersclub.com/forums/inde...t=0#entry194162
  2. here's one for the gen2 fans... its the V6... Please wait a few seconds for Video to Load!
  3. OVERSTEER... still pretty nice... sounds good too
  4. wait which acc going to the amp? the blue on or the red one... just to clarify, the blue one isn't the acc wire it's the remote wire... it's only ON when the cd player is on... unlike the acc wire which is ON when the car is on... anyway the remote wire barely carries any power, it just carries a small signal that turns the amp on... connect all the neons in parallel and connect them to the acc wire behind the cig plug... that'd be your best power source from within the cabin
  5. i'v got LEDs in my sub box that turn on WITH the boot light... so all i did was connect them in parallel to the boot light... that way the LEDs only turn on when you open the boot (that way you don't need a switch for it)... now with the interior lights... do you want them on the whole time with a switch... or do you want them connected so as soon as you pull the key out they turn off (switched too)??? if it's option A then just connect the neons together in parallel and power them on from behind the headunit... tap into the 'memory' wire of the headunit (yellow on aftermarket hu) then connect a seperate switch in series... if it's option B then do the same as aption A but instead of connecting it to the 'memory' wire connect it to the 'acc' wire (red on aftermarket hu) and connect a seperate switch in series...
  6. a couple more ads... funny as... enjoy... Please wait a few seconds for Video to Load! Please wait a few seconds for Video to Load! Please wait a few seconds for Video to Load!
  7. D'Ice
    THE SECRET
    hahaha! Good call! FTWWW
  8. D'Ice
    THE SECRET
    doesn't work... coz if it was actually true then i'd be on au.bentlyownersclub.com not TOCAU lmao... but how mad would it be if it was for real... haven't you seen 'the chaser' episode about it... crackup
  9. ^^^ what this broda said... don't fear the camry... but if you are affraid i'd suggest u download the 'camry manual' maybe there's a way to inspect the belt without removing it...
  10. hahaha umm yea it depends on where u're actually installing it... if you want something that doesn't really show i'd suggest stitching the neon using strong string... but the best option would be to use black cable ties... i actually pierced through the back seats and 'threaded' the cable ties through there and tied the neon... when i did the footwell i drilled holes and 'threaded' the cable ties through there... i was actually using hot glue to stick the neon and it actually worked the neon just recently fell off after almost two years but then when i was redoing it i figured it'd be best to use cable ties... go with black cable ties as they camoflage real nicely...
  11. Cruise thread created... click HERE for the thread...
  12. yep... that's why it's called A-Style... Anal Style lmao hahaha
  13. CamCrew is hosting it's first Sydney/Central Coast cruise and bbq from Homebush to Terrigal on Sunday the 7th Oct 2007 and most of CamCrew's Sydney members happen to be TOCAU members as well so that's another plus. If you are interested in coming along then please notify me or an organizer either via pm or post it up on the thread so we can organize the bbq. For more info you can check out the CamCrew thread HERE... Cheers Saif
  14. 20s would be GANGSTAAA... if 235/35/19 can fit then i'm pretty sure 235/30/20 or 225/30/20 would definently fit... that'd be pimpin man
  15. yep I agree... Drag Race don't Street Race... i had to learn my lesson the hard way... but i seriously think that it's a good idea for the coppas to use undercover imports and P plated cars... the perfect detterant... this method stops people from street racing while having no effect on proper driving
