DHOUS
DHOUS last won the day on May 1 2014
DHOUS had the most liked content!
    2008 Kluger KXR AWD
    Lara Vic
DHOUS's Achievements
Community Regular
Community Regular (8/14)
  1. Thanks more details would be handy, mine is intermittent so not urgent at this time, I have checked around the windscreen and the plastic cowling below the screen but unable to find anything obvious. Cheers
  2. I am recently experiencing the same RHS dash/windscreen rattle early on travelling but seems to go away, also very annoying be glad to hear if someone comes up with a solution. The panel near the foot parking brake is not the issue this time I resolved that one early in the history of my vehicle
  3. Guys a lot of comments from you on engine oil but my original post was more related to transmission oil and the change in behaviour of the shift criteria, and this was my theory on the change in fuel consumption. good to hear some of you backing up my fuel consumption figures, all in the way you drive no leadfoot acceleration!!! On the other point of service costs after the capping runs out, they do get expensive, you need to talk with your service Manager and get only done what is necessary, if you look at your service book you will see there is a lot of fluff, I got what I thought a reasonable deal from my dealer doing just this, given that my wheels have only done 40,000km over 5 years this was a bit easier to negotiate, but I will always do this from now on. the last service cost me around $500 some earlier blogs suggested charges up around the $1000. Cheers Dhous
  4. the reason for that service was the vehicle is 2008 5yrs old but only just clicked over 40K. there is definitely a change in the transmission holding lower gears longer. Cheers Dhous
  5. guys I have recently had combined 40k -60k service and fuel consumption has changed, highway improved and got down to 8.2 on my usual run from Geelong to Latrobe Valley, but around town has increased currently around 10.2 yes I do try to drive smoothly no lead foot. My take on the changes is the transmission oil not engine oil, this service had changes in transmission and transfer box, I have detected that the lower gears are holding much longer before changing up than previously before the service. just my theory FYI Cheers Dhous
  6. The Prado is a different class of car with great offroad ability, but definately does not have more room than the Kluger and is not better to drive, a number of us over here in the Pilbara WA own Klugers, and drive Prados most days, our choice unanimously for urban travel is the Kluger. Cheers Dhous
  7. Let me say I am very happy with the Kluger but if I had to go over to Diesel the new Sante Fe would be on the list, if not staying with a Kluger would never be a bad decision. Cheers Dhous
  8. Holmsie I have just completed my lease as well but my Kluger has only done 35K, working away from home. I would like to suggest that your criteria would put you in Hyundai Sante fe territory, take a test run and let us know what you think. Cheers dhous
  9. Has anyone tried to install the new low profile nudge bar to the previous model, the dealer tells me it cant be done but I cannot see why not?? Dhous
  10. Greg I have a similar setup and got around 17ltr/100km hot windy conditions over 250km, my question is how did you manage the transmission, Auto ? and if so were you able to hold it smoothly enough to prevent the O/drive from dropping back, did you at any time manually select out of O/drive and maintain this, I found if you can maintain a smooth cruising style up to 100km/h its possible to keep it in O/D even though Toyota dont recommend it. It would be nice if Toyota could come up with an adjustmet for towing purposes. Regards Don
  11. Ricey did you finally find a Toyota dealer that still loves you? your previous blogs led me to believe you had clashed with the dealer and would not buy another toyota again. In all fairness if any dealer had read what you had done with that Kluger, they would not want to touch you with a fifty foot barge pole I look forward to the offroad test performance in the FJ Cruiser from you. Cheers Dhous
  12. Mayhewga just read your blog, I dont log in that much these days, R16TS was also the best car I ever had, good luck with the Kluger Cheers DHOUS
  13. Guys check this site for fog lights as it is one of the most comprehensive and detailed subject, even at the top of the forum you will see Scotts steering wheel blog, click on it and follow the history and all will be revealed good luck. Cheers Dhous
  14. G'day and welcome... I think you're referring to the fog lamps and how they're missing in the KX-R model? I've seen after-market kits available on ebay... I'm guessing these would need to be wired up separately and therefore need a special button fitted somewhere to your dash. On the KX-S, Grande and even Altitude I think... there is a dial on the headlight stalk to activate the fog lamps but I'm thinking this is missing from the KX-R? So to get the genuine fog lamps you may also need to invest in a different stalk for the steering wheel. Someone else may have actually done this and can be a little more precise with the experience.
