Hi all, just needed some input on comfort / handling on the following tyres. Any input would be very much appreciated 1. Toyo Proxes 4 2. Toyo Proxes T1R 3. Yokohama S Drive 4. Bridgestone Adrenaline RE001 Thank you very much :)
do u need to put aftermarket LED indicator lights or just replacing??
if you are replacing then be gentle and pull out the mirror using a piece of cloth under the mirror and pull towards you...then u will see 3 screws if i remembered correctly to remove the motor... u see the clips to the back cover....
if you need to put on aftermarket LED mirrors then u have to remove the inserts and follow as the above...
hope that helps :)
