DIY - Changing Gearbox Oil
ZZE12X Corolla Manual 5 spd/6spd ONLY
Recommended Comments
10 hours ago, Ron Swanson said:
Can the pics in this guide be put back up?
Unless Kenshin puts them back himself, no. You can thank Photobucket for changing their business practices.
Hi, newbie here. Sorry if I have done this incorrectly and I know this is an old post but I have a couple of questions if I may,
1. Just purchased a 2008 Corolla (10th Gen) that has a 6 speed gear box. Has 116,000kms on the clock. As far as I am aware the gearbox oil has never been changed. The service schedule in the book only says to “Inspect” every 40,000kms. This is a bit concerning to me. I change my 2002 Corolla (5 speed) gearbox oil every 40,000kms (has 185,000kms on the clock)
2. I see that the quantity of oil needed for the 6 speed is 2.3litres. I am assuming this is just so you know how much oil to buy? I “fill to spill” from the fill port on my 2002 5 speed gearbox. Would the 6 speed bee the same?
Thanks and regards
Add a Comment
