Unknown noise 06 dual cab turbo diesel
kevin06
Please help have unknown noise in 2006 turbo diesel dual cab hilux. Like a wup wup sound. Have reconditioned back diff, gearbox, front wheel bearings, tie rod ends and cv joints also tried different tyres and noise the same. If anyone can help be good running out of options. Thanks Kevin
rate of noise: engine speed, wheel speed, or no speed, & which end of car?
Suspect items:
bad tyres, inlet/exhaust leak, vacuum leak, airstream flapping cloth or rubber somewhere? bad tailshaft ctr brg?
seems to be coming from front, tried different tyres. does it with tail shafts off which suggests gearbox but had it checked hear it idleing and at speed
  • 2 months later...
Have you managed to fix or find out what's causing the noise? I have an 07 that has developed a similar problem. The sound seems to be coming from the passenger side and can be felt through the floor on that side. It is speed related and comes on at about 50km/h. I have replaced the bearings and swapped tyres but no change.
      Boot Dimensions?
    2. 1
      2007 - Floor mat
    3. 0
      2007 - floor mats
    4. 6
      Front parking sensors
      Cruise Control Not Engaging
    6. 0
      Head Unit with Apple CarPlay
    7. 4
    8. 1
      2007 - Floor mat
