1993 Camry - Wiring
Paul Godwin
I'm in the process of installing a dashcam on the old girl and I'm using the blackvue magic pro which uses 3 wires.
What I am after (somewhere behind the glovebox) is a permanent live source wire and one that is ACC (comes on with the ignition only). This si so I can take advantage of the parking mode and not worry about a flat battery.
any help please?
Err thanks but that doesn't answer the question. The point is to HARDWIRE it in and for that need 2 power sources.
All good found my own answer - add-a-circuit available from Supercheap is just the answer - allows a fused circuit to be taped into the fuseblock. Bonus = hidden wires, professional installation and ability to remove easily if needed.
      Boot Dimensions?
      2007 - Floor mat
      2007 - floor mats
    4. 6
      Front parking sensors
      Cruise Control Not Engaging
      Head Unit with Apple CarPlay
    7. 4
      2007 - Floor mat
