Tensioner or Idler pulley
heathaurion
Hey all,
My '09 Aurion started a loud squealing / slight rattling noise today.  The mechanic says it's either the idler or tensioner pulley. With pressure on the pulleys using a spanner on the bolt heads, the noise went away.
Anyhow .... has this happened to anyone else and is this a common aurion fault?
cheers all- Heath
  • 4 weeks later...
  • 4 months later...
One likely source of the noise, says Toyota, is a worn No. 2 idler pulley. Replacing it with a more rugged design (Part No. 16604-0P011) and adding an extra pulley cover plate (Part No. 16649-31020) should silence the noise in short order.
Located this piece of information doing Google searches for 2GR FE engine.
Toyota Squeaking noise from engine compartment.doc
