Aurion - first service
zr6
Does anyone know when the first service is scheduled? I'm not referring to the 1000 km "walkaround" service. One dealer said it's at 5000 km and another one said it's at 7500 km.
I just had my 1000km "walkaround" service done this morning.
At the end of the service, they told me the next service is at 15000km.
It has to do with how often you drive the car, so check with the dealership.
If its like the Camry you can do the in-between services (7500kms) or to keep in warranty just do the 15,000km ones. Oil changes often are a good thing if you intend to keep the car for a long time.
Also before you go on a long trip its good to have everything checked over.
1st service (Visual only + adjustments, no oil change) is before 5000km or 3 months. The real 1st service is 7500km's
Good luck
Adrian
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
