will this fit?
TheStapler
hey
i have a corolla 2002 just want to know if these mags will fit.
ZIEX- FALKEN MAGS WHEELS
ZE512 - "ALT Seven Wheels" made in Japan
Size 205/40R16 83H M+S
they are multiply stud patten
and how much would tyres cost for them??
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=190103352836
thats the link to them.
Edited by TheStapler
Multifit will fit corolla ... it needs to be 4x100 with an offset up to 40
ascent has pattern of 4 x 114.3 35...38 offset 67.0 centre hole
corolla has 4x100 35...40offset 54.1 centre hole
they will go on but centre hole will be too big so you need Hubrings ... i got mine from USA
i have a set that would match a 67mm hole selling if you want can have for $10 plus postage
they keep the rim in the centre .. i would not put rim on without them
i got wrong size i needed 73mm rings
hope this helps ...
New tyres .... $100 > depends on brand you want
or about $55 second hand with near new tread ( but thats melb)
current tyres on it are well below weight/speed rating of 88 for a rolla so you will need new tyres
yes they should fit ... pulsar 4x100 if the can tell you the offset .. how far they would stick out from the wheel studs .. don't want more than 40 less than 35 or it will rub on either side.. again wiehgt rating of tyres shown in ad is 82 it must me 88 for roadworthy .... unless you get new tyres
      Gen 6 Cluster Backlighting Issues
      Hilux surf
    3. 6
      Buying a Hilux / Surf
      05 hiace ecu
      1989 Hilux Low Voltage
    6. 27
      FUEL WARNING MESSAGE
    7. 27
    8. 27
      Wanting to build my car.
      2004 hzj79 surging/jolting
