TRD and other suspension
grimlock
Yes you can just buy by the shocks by them selves. You could use Konis or any other brand that fits, depends on your budget. Whiteline sells Konis. www.trdsales.com has a complete set that is made and sold as TRD for approx $750 plus postage. Which is quite resonable plus fitting of course.
i got d2 coilovers. not much to worry about as it is all adjustable and warranty is new for old if there are any leaks.
i can only think of screaminrolla who is using new shockers in the factory struts. yes you can use your king springs with new shockers.
i got a set of second hand oe struts with shockers if you are interested these were removed from corollas that got coilovers. but you should get shortened travel shockers to stop this problem from happening again.
that is a good choice: TRD shocks + TRD lowering springs...
i imagine that the ride would be more smooth & comfortable than mi TTE Full adjustable suspension kit.
theres is other options like:
TEIN Damper Kit (height adjustable USD800.00)
TEIN Super Damper Kit (height & damper adjustable USD1,300.00)
TTE Full Suspension Kit (height adjustable, is made by Eibach, very rigid)
Eibach Super Street (coilover, is the same as the TTE)
TRD suspension kit (i mentioned about it)
C-ONE (is made by KONI shocks + C-ONE springs, cost aprox. $1,200)
and it have other that is in Europe, (i didn't know the names)
i hope my information will help you guys.
warranty covered my shock.
WOOOO HOOOO.
get kings springs with your corolla people and lower no more than 2inch.
heheheheh
STOP PRESS
Apparently when they located my VIN number on the database.
My car is not underwarranty due to Supercharger WTF?
HOw did they know this?
bummer i guess if you lower your car it is still covered, unless you get a Supercharger.
Silly ***** toyota.
as it is adjustable you need to work out how to adjust and align everything. it makes a big difference. if it is still not comfortable to your liking then coilovers are not for you.
i have tried the trd sportivo suspension kit in an echo. i remember it as firm.
in a month i will have the waydo, trd shocks.
will post up.
at the moment if you people are looking for lower shocks, no aftermart company makes them
KYb Koni ETC.
thats if your looking for just sports suspension
not race setup.
i've been researching.
Plus i've got a fish tank now.
Who's got fish?
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
      Upgrade from 2012 to 2023
    9. 3
      Towbars
